size problems with ASA and 0.8 mm nozzle
Dear All.
I recently changed the nozzle of my Prusa printers (i3 Mk3S+ and Mini+) to 0.8 mm and started using ASA instead of PETG. Now holes, and sometimes outer dimensions are not identical with the original design. Sometimes up to 10% difference (holes too small). I started to adjust the designs in my CAD software but I wonder if it is possible to get 1:1 results with proper Prusa Slicer settings?! I use Prusament ASA settings as Polymaker PolyLite settings are not available and mostly print with 100% infill as parts are mostly small (height < 2cm). Thanks in advance for any help and tips.
regards,
Chris
Respondido : 22/03/2022 4:33 pm
