Show/Hide Labels in main window
Tango
(@tango)
I've been searching with variations of "object labels" and "object names," as well as a few other terms and can't find an answer to this.
Somehow I turned on a setting, somewhere in PrusaSlicer, so it shows the names of the objects on the print bed. I don't mean the list of objects in the sidebar, but labels over the actual objects, like this:
On the one hand, I love this feature because there are many times I'd find it helpful, but how do I turn it off? I have two Macs I use PrusaSlicer on. One shows these and one does not
Opublikowany : 03/03/2024 1:55 am
RE: Show/Hide Labels in main window
Tango, its the keyboard shortcut "E" (Show/Hide Object/instance labels).  Its listed in the keyboard shortcuts.  Which itself is available from either Help>Keyboard Shortcuts or just using the keyboard "?".
Opublikowany : 03/03/2024 10:12 am
Tango
(@tango)
Posted by: @neophyl
Ah!
I was so busy looking through all the settings and the configuration options I never thought to check shortcuts! Did not expect it to be so easy!
Opublikowany : 03/03/2024 4:52 pm
