Setting Z speed and acceleration?
mikeuk
(@mikeuk)
I am trying out PrusaSlicer 2.0 inside updated version of Repetier-host with my 3rd party 3d printer. I am having a problem when that print start the z move too fast and lost step. Is there anyway to change the Z speed and acceleration? The closest thing I have found is the max Z speed limit which is set as 12mm/s at the moment.
Opublikowany : 12/08/2019 7:45 pm
RE: Setting Z speed and acceleration?
Under Printer settings > Machine Limits  there is a whole host of speed settings for acceleration and jerk etc as well as max speed.
Opublikowany : 13/08/2019 7:53 am
mikeuk
(@mikeuk)
Thanks for sharing your setting I will experiment with the values.
Opublikowany : 13/08/2019 11:18 pm
Those are the prusa defaults.
If you add new printer in Prusa Slicer and select one using the wizard you can then have a look at all the default settings for the prusa printers/filaments/print settings etc as well as what custom gcode etc.  While thats not directly applicable to other printers it does give you something to start with at least and is what I did when adding my cr10s as a new printer.
Opublikowany : 14/08/2019 6:08 am
