Setting up Profiles for 1.0mm and larger nozzles Help Please:
I have the Bontech CHT Nozzles that include 1.0, 1.4 and even 1.8mm Nozzles for 1.75mm filement.
I thought I had figured it out.. I did manage to slice some files for the machine with the 1.0mm nozzle.. but so far I'm messed up it printed much slower than the "Generic PETG" for the 0.8mm
And now i screwed it up in the Slicer I see only a Couple User Settings under Print Settings: and while I have tried to make it all "Default" I am getting this message: Flow:mm3_per_mm()produced negative flow. Did you set some extrusion width to small?
Thoughts, Ideas, Manual I should read.. PS: I have been using for a few years now.. but first time trying to get big nozzles working.
Postato : 18/01/2024 9:30 pm
