Setting separate model parts to original coordinates
Tobycwood
(@tobycwood)
I am using a Toolchanger, but I'd bet this also applies to the MMU and to other similar devices.
I'm trying to print multimaterials with a multi-part model. It seems the only way I can get the four parts of the the model (4 separate stl files) to line up correctly with each other per their original coordinates is to add them as one model. However, If I Add the four parts as one I cannot see a way to assign tools to each part. What am I missing???
Napsal : 30/08/2022 7:07 pm
Ringarn67
(@ringarn67)
RE: Setting separate model parts to original coordinates
@tobycwood
Add the four parts as one, just as you did, and then Right-click on model -> Split -> To parts
Assign each part to the tool of your choice
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Napsal : 30/08/2022 11:16 pm
