Set random seam as default option?
TI7ANIUM
(@ti7anium)
Is there any way to set random seam position as the default setting/have it not change when I close and reopen Prusa slicer? I've tried looking around on google and in the forums but I can't seem to find an answer.
Thanks
Best Answer by JoanTabb:
You could try saving this setting as a modified print settings profile.
however if you change layer height settings frequently you may need to set up several custom profiles.
Publié : 29/03/2023 3:24 am
RE: Set random seam as default option?
Publié : 29/03/2023 10:31 am
1 personnes ont aimé
You should save changes to the settings, as Joan has already pointed out. Then you can export the entire profile.
You can import the profile with all saved settings after a new installation or on another PS installation.
wbr,
Karl
Publié : 29/03/2023 2:46 pm
