Set random seam as default option?
TI7ANIUM
(@ti7anium)
Is there any way to set random seam position as the default setting/have it not change when I close and reopen Prusa slicer? I've tried looking around on google and in the forums but I can't seem to find an answer.
Thanks
Best Answer by JoanTabb:
You could try saving this setting as a modified print settings profile.
however if you change layer height settings frequently you may need to set up several custom profiles.
Posted : 29/03/2023 3:24 am
RE: Set random seam as default option?
Posted : 29/03/2023 10:31 am
You should save changes to the settings, as Joan has already pointed out. Then you can export the entire profile.
You can import the profile with all saved settings after a new installation or on another PS installation.
wbr,
Karl
Posted : 29/03/2023 2:46 pm
