Set order of print for Multiple Items
dojo44
(@dojo44)
When printing multiple items I think it might be a good idea to be able to set the order of completion and execution.  For example I have 6 different items to print at one time.  Let's say that a couple are much larger than the others.  My theory is that the smaller ones get less print time allowing the filament to cool, ruining the adhesion.  To address this the order of execution and completion could be set in the slicer so that item 1 is executed and completed prior to moving onto item 2, etc...  This would save time in resetting a print job.  Naturally there could be some limitations, possibly height of objects...
Veröffentlicht : 24/02/2022 9:12 pm
Swiss_Cheese
(@swiss_cheese)
RE: Set order of print for Multiple Items
@dojo44
It's called  Sequential printing
Print Settings/ Output options/[Sequential printing] Complete individual objects: (Tick the box)
Read up on it and learn how to set it up before you use it, you are correct height matters and so does depth as well as the number order in the sidebar.
Quick tip: you can use the travel view to check that it's printing in the order you want it before export.
I'm pretty sure Prusa has some info about this on there knowledgeBase thingy, as well I think there are a couple threads here on the forums about it.
Good Luck
Swiss_Cheese
The Filament Whisperer
Veröffentlicht : 24/02/2022 9:30 pm
Swiss_Cheese
(@swiss_cheese)
@dojo44
This might help,?
https://help.prusa3d.com/en/article/sequential-printing_124589/
But the article doesn't seem to cover everything. so read it but look beyond.
Veröffentlicht : 25/02/2022 2:06 am
