Set datadir path in Slicer setting
i use "--datadir" parameter for running slicer from shortcut, its ok. But if slicer is starting doubleclicking to associated file (*.3mf) is used default datadir path. Is possible add adjustable datadir path to slicer setting, which are used if slicer is starting without datadir parameters?
For everyone who uses a slicer in the cloud or NAS, this little change would be of big help.
Thank you
Respondido : 19/04/2020 10:16 am
RE: Set datadir path in Slicer setting
I think the association can be changed to include a "--datadir" in Windows.
I used the "--datadir" option myself before migrating to Linux.
To let the Prusa developers to see this feature request, it is best to post an issue here.
Respondido : 19/04/2020 10:37 am
