sequential printing with 2.0
Hi All,
I am struggling to get the prusaslicer 2.0.0 to do sequential printing. I enabled it print setting made sure the extruder clearances were good but it just prints them at the same time. I am used to S3D and using multiple processes to accomplish the same thing but I am having a hard time in prusa 2.0 as noob.
Thank you in advance,
Dan
RE: sequential printing with 2.0
I believe the G-code will print sequentially, only the G-code preview shows all layers as if printed together.
Note if the parts are too close together/placed such that it's not possible to completely finish one before the other without causing collisions, it will still print each one in groups of layers. E.g., 2 parts aligned in Y, rear part printed first, front part second. Can't finish rear part without risk of hitting it with X axis, so both parts are printed in increments according to the "distance to X axis" setting.
