Sequential Printing in Prusa Slicer
jtlocke
(@jtlocke)
I can't get this work for the life of me. Even with just 2 benchies. It either tells me its too close, and when I spread them out it says objects are too tall. Do I need to change the 45 radius and 25 height parameters? I see in manual for old slicer it says I need to order objects, but don't see how to do this in current slicer. Can someone explain this part to me? What am I missing here? I realize objects will need to be spaced out for clearance but want to print multiple objects in tpu and petg and don't want extra stringing or a failure of one model to ruin multiples. Printer is MK3s if that matters. Thanks in advance. I googled for hours before reaching out here, so hopefully someone here can help
Opublikowany : 05/03/2020 12:09 am
RE: Sequential Printing in Prusa Slicer
Older slicer version the order is the order in which you add the models.  You had no control over that.
The latest 2.2.0rc have added the ability to reorder the parts https://github.com/prusa3d/PrusaSlicer/releases
Opublikowany : 05/03/2020 7:18 am
jtlocke
(@jtlocke)
Posted by: @neophyl
Thanks for the info! I downloaded the alpha 4 version. I now can see the labels. I put them in correct order, but it still says Objects are too tall... What should I have my extruder clearance set at? I used the defaults, then I tried changing. Still can't get it to work. Not sure if its just the extruder clearance, or if I need to change some other setting to make it work. Any help appreciated. Thanks in advance
Opublikowany : 05/03/2020 12:17 pm
