Sequential Printing and Arranging Multiple Instances
btrout
(@btrout)
When I am printing multiple instances of a single Item, the Arrange function (Keyboard Shortcut "A") does a nice job of arranging the items, but their print sequences seem somewhat random.  They are certainly not arranged Left to Right, Front to Back as recommended. And with multiple instances one cannot arrange them by hand.
What I ended up doing was pasting multiples of the same item into PrusaSlicer.  Then one can arrange their printing order by hand in the right hand window.
Is there a way to get Arrange to order them correctly?
Thanks,
Bob
After auto Arrange...
After hand arranging...
Publié : 31/03/2022 1:51 am
Swiss_Cheese
(@swiss_cheese)
RE: Sequential Printing and Arranging Multiple Instances
Currently arranging them by hand is the way to go, the algorithm for automatic placement is woefully lacking with no other way to describe it. Regardless of using instances of individual objects.
Good Luck
Swiss_Cheese
The Filament Whisperer
Publié : 01/04/2022 1:11 am
btrout
(@btrout)
Swiss_Cheese,
Alrighty then.  Thank you for the info.
Bob
Publié : 01/04/2022 2:28 am
Swiss_Cheese
(@swiss_cheese)
BTW, that was supposed to read " instances or individual objects." not " instances of individual objects."
Regards
Swiss_Cheese
Publié : 01/04/2022 3:44 am
T_om
 T_om
(@t_om)
Yep.  This still pretty much sucks.  At least let the added instances be shifted manually if the programming is too hard.
Tom
Publié : 29/07/2023 2:59 pm
jseyfert3
(@jseyfert3)
You can. Simply drag and drop them in the list on the right. They change order without losing the positions on the bed.
I recommend finding the first one you want to print, drag it to the bottom of the list. Find second one and drag to the bottom. Repeat till they are arranged.
Posted by: @t_om
Tom
Publié : 02/08/2023 2:25 am
T_om
 T_om
(@t_om)
Nope.  A red circle/bar appears when trying to pull one instance ahead or behind another.  No change in order allowed..
Posted by: @jseyfert3
Posted by: @t_om
Tom
Publié : 02/08/2023 2:50 am
jseyfert3
(@jseyfert3)
Perhaps not with instances. With parts you definitely can. I’m usually doing parts, not instances, so perhaps I never tried arranging instances on the right hand list.
Posted by: @t_om
Posted by: @t_om
Tom
Publié : 02/08/2023 2:55 am
T_om
 T_om
(@t_om)
Of course parts can me shifted.  This thread is about instances, not parts.
Publié : 02/08/2023 3:05 am
nikoumwelt
(@nikoumwelt)
Membre
Please forgive me if I am missing something obvious but don't the instances print front to back right to left once they're sliced, regardless of the instance name or sequence within the instances list? What is the specific thing that you want to do that the software does not allow?
I discovered this thread soon after contemplating a potentially related problem. I would love to be able to generate a sort of "grid tiling" of instances of the same part with a specified tile spacing, similar to how it's done in for example Fusion 360.
Specify:
X distance
X quantity
Y distance
Y quantity
Generate the evenly spaced grid.
Posted by: @btrout
Thanks,
Bob
Publié : 02/08/2023 9:41 pm
