Send to connect wrongly labels require high flow nozzle / hardened
NoeG
 NoeG
(@noeg)
 I'm getting warnings about requiring a high flow / hardened nozzle when trying to print with PLA (see attached pictures - not sure how to upload in line)
I'm using standard prusament PLA / non High flow nozzle
Is the fact that the message is green meaning "everything is OK"? It would feel misleading.
This topic was modified 2 years temu 3 times by NoeG
Opublikowany : 23/09/2024 9:51 am
Bruce
(@bruce-2)
RE: Send to connect wrongly labels require high flow nozzle / hardened
I'm getting the same message from Slicer 2.81. It says I don't have a compatible printer and won't send to Connect. If I export the file and then open Connect on my browser it will load and transfer the file to my XL5T. I can't find where in slicer to tell it not to use a high flow or abrasive nozzle.
Opublikowany : 23/09/2024 10:17 am
Reported issue already on the PS github https://github.com/prusa3d/PrusaSlicer/issues/13398
Opublikowany : 23/09/2024 1:39 pm
