Scaling scales both directions
Havocentral
(@havocentral)
When resizing an object or support enforcer the models scales in the direction chosen and the opposite direction as well, While when scaling a model this isnt a big deal, but when try to place a support enforcer or blocker, its an issue trying to get it both the right size and placment when trying to move just the right side a little further, the left side does as well. Or try to move the top up, the bottom goes lower too.
Opublikowany : 26/03/2020 4:33 am
RE: Scaling scales both directions
Was there a question in there somewhere ?  Yes scaling is proportional and happens on both/multiple sides of a modifier.  That's the way its been implemented.
If you are unhappy with how it works then may I suggest you raise a feature request at https://github.com/prusa3d/PrusaSlicer/issues where it can be added to the 1235 other open issues.  I'm sure the devs will give it the attention it deserves.
Opublikowany : 26/03/2020 7:08 am
