Scaling or Sizing prints by a numerical value
[Gelöst] Scaling or Sizing prints by a numerical value
3DPO
 3DPO
(@3dpo)
Hello, i just made a nice Xenomorph print from an all in one STL file. Image below. Now i have the individual STL files for 7 separate parts and want to scale them all up to a similar size to make one crazy big Alien Queen. But i cannot seem to find a way to do it in Prusaslicer. I can see fit to print volume but that means they are all unequally scaled if i make each an individual print. I can see the XYZ boxes with numerals when i click the scale option in the left toolbar but the values only seem to be controlled by moving my mouse and i cannot get accurate numbers. I've only had the printer a few months and its great but this simple task has me stumped. Help apppreciated.
PS: MK3S+ with MMU2s. All firmware & software up to date.
Best Answer by JoanTabb:
Hi 3DPO,
welcome to the group.
there is a manual scaling option in the bottom right hand corner of the Prusa Slicer Page
Dieses Thema wurde geändert Vor 5 years von 3DPO
If its not broken, leave it alone. Less is more.
Veröffentlicht : 19/06/2021 7:06 pm
RE: Scaling or Sizing prints by a numerical value
Hi 3DPO,
Veröffentlicht : 19/06/2021 8:41 pm
3DPO
 3DPO
(@3dpo)
@joantabb
Hi Joan, im using Prusaslicer on ubuntu. I dont see it. I'll try send a screenshot
Veröffentlicht : 19/06/2021 8:48 pm
3DPO
 3DPO
(@3dpo)
@joantabb
Oh, your screenshot only shows on the Simple tab. I was in the advanced tab trying to find it. Thanks a million, i can work with that. I'll flick you a pic of the monster when i get it completed. Many thanks.
Veröffentlicht : 19/06/2021 9:09 pm
3DPO
 3DPO
(@3dpo)
@joantabb
Peter Powell 2 liner stunt kites are awesome btw. I grew up with a sweet 5 footer. Best stunt was on a windy night to make a long tail, tie in folded newspapers, light them up and let her up and away. It was breathtaking.
Veröffentlicht : 19/06/2021 9:21 pm
jsw
 jsw
(@jsw)
I use PrusaSlicer on Ubuntu as well and I've done things such as this.
PrusaSlicer is not only good for slicing to print, it's good for cutting apart larger objects into printable pieces and scaling, if needed, by a consistent factor.
The 'cut' function in PS will work on objects that are much larger than the maximum build volume.  You can rotate an object by 90 degrees if you need to slice it horizontally.  Just slice, keeping only one part, and re-export that part to a .stl file.
I've also at times re-imported some of the cut-up pieces back into FreeCAD, converted the mesh back to solid, and edited some more.
Veröffentlicht : 20/06/2021 12:14 pm
3DPO
 3DPO
(@3dpo)
@jsw
Thanks jsw,,
for slicing and code i'm inexperienced. I have a F360 account running and i have printed some very basic makes. Servo & battery holders so far. But i keep reading here and learning from everyone who takes time to post instruction. Thanks for commenting, i will try out your points in future prints. Have a great day.
Veröffentlicht : 20/06/2021 12:29 pm
