Scaling in Prusa Slicer Comand Line Help
Hello,
I want to use the command line for Prusa 2.9+, specifically I want to change the size of the stl models and export the sliced gcode. I was playing with the --scale and --scale-to-fit parameters but so far I can't get a non-uniform scale for the model, does Prusa support that through the command line? If so, how can I do it. I apologize if the doubt is simple due to my lack of knowledge.
Best regards 🙂
Opublikowany : 24/03/2025 4:38 pm
