scale issue coming from C4D
Hello,
When I export a cylindar (100mm x 10mm) as an stl or obj from C4D (R25) it imports into prusaslicer as 200mm x 200mm x 10mm but a cube (100mm x 100mm x 10mm) imports in just fine.
Strange how only x and y get doubled but z stays 10mm and a cube works fine. Any advice?
Veröffentlicht : 08/05/2023 11:04 pm
RE: scale issue coming from C4D
Is your cad defining a cylinder with its radius instead of diameter ? You should use a 3rd party tool to check the stl output. Something like 3D-tool.
Veröffentlicht : 09/05/2023 7:14 am
