[Rozwiązany] Scale by entered value
studiodave56
(@studiodave56)
I really like using Prusa slicer except that I do a lot of scaling up and down for fitting different things, but the slider only method does not work for me in most cases, are there any plans or is there a hidden way to scale something like, x=98.5% y=99.3% or anything that I enter? I can not get accurate values with the slider and holding shift for 5% increments is almost useless, for me.
Opublikowany : 25/09/2024 11:58 pm
studiodave56
(@studiodave56)
RE: Scale by entered value
I found this answer from a different post, I have been using Prusa Slicer for 8 months and never knew about the side panel that comes up when you press, "Shift Tab"
Opublikowany : 26/09/2024 12:09 am
