Saving profiles on shared drive
[Résolu] Saving profiles on shared drive
Andrew C
(@andrew-c)
I have to switch between workstations and make tweaks to settings. How would you save the configuration files to shared drive (Dropbox, Synology Drive, etc) to avoid having duplicate profiles?
Publié : 28/12/2021 1:44 pm
RE: Saving profiles on shared drive
You could use the datadir switch on your startup shortcut.  In windows at least.  Not sure about the other operating systems.
A start shortcut or batch file with "prusa-slicer.exe --datadir settings" for example would launch with the program getting and storing its settings from a local folder called "settings".  This is useful if you are having profile problems as it will then go through the configuration wizard (unless there is a settings folder locally with settings in of course) and generate a clean setup.  But you point it to your desired folder to use a shared setup.   I used to use it that way with dropbox back in the v1.47 days.
There's other threads on here already asking the same question if you search and I seem to recall they mention symlinks etc which may be applicable to no windows OS.
Publié : 28/12/2021 1:57 pm
On the Mac I moved the profiles/settings directory to a shared drive and use symlinks from my computers to point to the shared location.
Publié : 28/12/2021 3:09 pm
Andrew C
(@andrew-c)
The datadir method works for my needs. Thanks!
Publié : 28/12/2021 10:52 pm
vj_andrei
(@vj_andrei)
Posted by: @fuchsr
Can you tell how did you do this? I have multiple OSX computers and liked to have settings to sync.
Ce message a été modifié il y a 3 years par vj_andrei
Publié : 12/12/2022 7:34 am
bennnjil
(@bennnjil)
Thanks for the tip, solved my issue!
Publié : 03/04/2023 10:23 am
  • Go to Prusaslicer's Help menu and select Show Configuration Folder
  • Go up one level and note the location of it. It's usually /Users/username/Library/Application Support/PrusaSlicer (alphas and betas have different names).
  • Create a backup copy, just in case.
  • Copy the configuration folder to your network drive and delete the original. Note the new pathname, in my case /Users/username/OneDrive/3D Printing/Software/PrusaSlicer/PrusaSlicer
  • Open a terminal window.
  • Create a symlink (ln -s sourcefile destinationfile), e.g.:
ln -s /Users/username/OneDrive/3D Printing/Software/PrusaSlicer/PrusaSlicer /Users/username/Library/Application Support/PrusaSlicer
Publié : 03/04/2023 11:25 am
2 personnes ont aimé
bennnjil
(@bennnjil)
Did smb tried this solution? https://mac.eltima.com/mount-google-drive.html
Publié : 07/04/2023 1:22 pm
