Retractions on thin perimeters/walls Hinge Model
Ingoingo
(@ingoingo)
is there a way to supress the retractions on this thin wall?
Or any tweak in the settings to print it in a different way?
My Problem is that this thin wall acts as a hinge and due to those retractions there are weak spots in the hinge.
I already tried to change some parameters in the advanced section of the arachne permieter generator without much sucess. (retraction points changed a little but not completely).
Spanner04
Here you can find the .stl model to test it in your slicer:
https://www.thingiverse.com/thing:6230454
bg Ingo
This topic was modified 2 years ago 2 times by Ingoingo
Posted : 22/09/2023 4:51 pm
Ingoingo
(@ingoingo)
Picture of bad bond:
Ok i found a way. But i did not improve the bond of the single perimeter to the others. (avoid crossing permimeters on)
It supresses the retractions on this section but it seems the problem is not the retraction. I think the missing overlap between ths single permieter and the other 3 perimeter is causing the bad bond.
i even tried different pressure advance values, with/without retract and extra lenght on restart. nothing worked.
This post was modified 2 years ago by Ingoingo
Posted : 22/09/2023 6:17 pm
