Resizing the build plater
Mr Moo
(@mr-moo)
Hello,
I have searched various places but to no avail, I am hoping I can find the answer here....
I would like to resize the build plater for SLA printing so I can use the excellent auto support feature for printing on my larger format resin printing.  Despite changing the dimensions in the settings and creating a new "printer" the build plater stays the same size as the Prusa SL1.
Can this even be done?
Many Thanks in advance,
Mr Moo
Opublikowany : 12/07/2021 9:43 am
RE: Resizing the build plater
Are you specifically asking for an answer in PrusaSlicer?  I do not see that in your request?
Opublikowany : 12/07/2021 11:00 am
I just added in a Sl1 printer to my PS settings and then modified it to a 200x120mm size and saved it as a new printer.  It saved fine and the plater is now 200x120mm in Prusa Slicer.  The setting I changed was in Printer Settings>General>Bed Shape.  Theres a Set button visible when you are in advanced or expert mode.  Just click it, edit the bed size and then save the printer profile as a new one (cant use the default name as PS doesnt allow you to over write any system profiles).
Now when I select the new printer the plater is the new size.
So what exactly did you edit ?
Opublikowany : 12/07/2021 1:55 pm
