reset slicer to stock
Honegod
(@honegod)
how do I remove all changes I entered into Prusaslicer 2.2.0 ?
I have been "tweaking" settings to see what happens and now my prints suck.
i want to go back to offifial Prusa settings but I see no button to push to discard all changes.
I tried uninstalling and reinstalling Pslicer but I think it imported my "settings"
Postato : 16/11/2020 4:35 am
RE: reset slicer to stock
Posted by: @phillipl652a
on the right hand side of Prusa Slicer, there is a window with options...
at the top there are standard settings, at the bottom, are the modified settings
choose a standard layer height setting, a stadard filament setting and a stadard printer setting. and you are back to standard
Postato : 16/11/2020 2:03 pm
Yeah you cant actually edit any of the built in profiles using Prusa Slicer so they should be available to you at all times.  Any extra ones you have saved you can click the X to delete it (select your custom profile and click the X icon next to the drop down).
Postato : 16/11/2020 2:20 pm
For a complete reset, you can run the configuration manager and check the box on the 1st screen that tells it to remove all user profiles.
Postato : 16/11/2020 2:47 pm
