Repeat 'Add negative volume'
brianjordan
(@brianjordan-2)
Using PrusaSlicer 2.9.5 I would like to trim a couple of aspects of an stl by using the 'add negative volume' tool. The stl is a representation of our village obtained through the map2model.com site and although the result is mostly very good I need to trim a couple of buildings as one is too tall and one is too long. I can add negative volume to either one but not both to obtain the result I need. Researching this it seems that the effect is only applied when the model is sliced so there is no way back to apply the effect again. Unless you know different?
Dieses Thema wurde geändert Vor 1 day von brianjordan
Flashforge finder -> Flashforge Creator Pro -> Prusa MK3S -> Prusa MK4S ->???
Veröffentlicht : 15/06/2026 3:18 pm
RE: Repeat 'Add negative volume'
You can add multiple negative volumes to a model in the slicer but yes those volumes do not actually change the underlying model, they only effect the output of the slice.
If you want to make changes to a model then do it in CAD.
Veröffentlicht : 15/06/2026 3:31 pm
ssmith
(@ssmith)
You might try exporting the plate as an STL after each use of the tool, then loading that STL for the next edit.
Veröffentlicht : 15/06/2026 4:32 pm
brianjordan
(@brianjordan-2)
Thank you, I'll give it a go.
B
Veröffentlicht : 16/06/2026 10:39 am
brianjordan
(@brianjordan-2)
Thanks. I didn't realise that was possible. Something else to try...
B
Veröffentlicht : 16/06/2026 10:41 am
