Rename printer after completing setup?
dameion.d
(@dameion-d)
I took the default name when wetting up my printer ("Original Prusa MK 4 0.4 nozzle") in Prusa Slicer (v. 2.7.2) and want to rename it to something more compact, like "Prusa MK". Is this possible though the software w/o having to "add" the same printer again?
Napsal : 26/03/2024 4:28 pm
RE: Rename printer after completing setup?
You can't rename system profiles.  So even if you tried to add it again you wouldn't be able to change the name.  You can create a copy of the template and give it a custom name though.   That would add it to the User Presets section rather than the system presets.  You could then run through the wizard again to remove the printer but that would possibly remove the associated filaments and print profiles too (depending on if anything else is installed that might install them) unless you also made copies of those.
Napsal : 26/03/2024 6:08 pm
