Removing Physical Printer Presets
How do you remove physical printer presets in PrusaSlicer I made a mistake making one of them and now I don't know how to remove it. Is there a way to do it or have they not added this feature yet?
Best Answer by _KaszpiR_:
Enable Expert Mode just to be sure.
In the right menu you have a printer list, choose preset that you want to delete. On the right there is a small cog icon next to the printer selected, click it.
You should see new window (or tab) with that printer profile. On the top left corner next to the drop-down menu are icons, one of them is big X which can be used to delete currently selected preset.
RE: Removing Physical Printer Presets
I want to remove my "MK4" printer, since I've upgraded to CoreOne, and this big red X is greyed out, so its disabled. How can I remove it anyways?
Run the configuration wizard again and unselect the printer/nozzle combinations you don't want any more.
I did it. I clicked "select none" and then coreOne, and the MK4 is still there 😀 Maybe I will clean reinstall PrusaSlicer, and see if it helps.
I am having the exact same problem. There is no way to remove old presets. I upgraded from MK4S to Core One+ and I have no way to remove the MK4S printers from the list.
I just tried this and for me its working fine. One thing you do have to be aware of though is that there are 2 sections that contain the MK4 printers (and the XL btw).
There's the latest profiles located towards the top of the listings but there's also a section right at the bottom for 'Legacy' profiles. Take a look and make sure one of the legacy profiles is not selected too. Then proceed through the steps and finish the wizard.
That worked, thank you.
Ahh, thanks a lot!
