Récupérer les paramètres système réglages d'impression et imprimante
Julnar
(@julnar)
Bonjour
Comment peut on récupérer les paramètres système réglages d'impression et imprimante.
A la suite d'une manip inconnue je n'ai plus les paramètres système réglages d'impression et imprimante, voir les copies d'écran en PJ
D'avance merci
Cordialement
Veröffentlicht : 24/07/2025 4:12 pm
RE: Récupérer les paramètres système réglages d'impression et imprimante
From the little information you have posted with the tiny picture we cant tell.  For example do you still have the default printer selected that you are expecting the system presets for ?  We cant see.
Profile availability is based on multiple factors. You could try running the configuration wizard again to make sure that you have the desired printers and filament and print settings installed.  Once that is confirmed then you need to make sure that the correct printer is selected.  The profiles that are available to the printer should then be visible..
If you don't have a standard printer selected then that will reduce the profiles that can be seen.
Not sure if thats the answer you are looking for as I had to use google translate on your query, after all you did post in the English section of the forum and sometimes google does not handle nuance.
Veröffentlicht : 24/07/2025 4:48 pm
Sébastien Dubois
(@sebastien-dubois)
Mitglied
The picture is sufficient to understand the issue. All the system presets  disappeared. And the question is how to recover them...
Veröffentlicht : 11/09/2025 5:28 am
Which printer have you selected?
Veröffentlicht : 11/09/2025 11:40 am
