Purge on print start
woogerboy21
(@woogerboy21)
Hello!  I was curious if there is a way to configure a printer profile to purge an amount of filament in the purge tower at the beginning of the print before actually printing the sliced part?  I have a multiple extruder single hotend printer and when starting new prints some of the last color used is still hanging out in the hotend that needs purged before printing.
Thanks
Publié : 14/01/2022 2:26 am
RE: Purge on print start
One simple way is to print a larger number of Skirt lines...
then the imperfect filament would be printed into the skirt before starting the model!
Publié : 14/01/2022 4:30 am
woogerboy21
(@woogerboy21)
Hmm... not a bad idea.  I should measure the amount of filament it takes to figure out how large a brim that might be.  It's definitely larger than the default purge line.
Publié : 14/01/2022 6:07 am
woogerboy21
(@woogerboy21)
Posted by: @joantabb
This seems to be a pretty good solution, thanks for the recommendation.  The only drawback is the size of the part your printing.  The smaller it gets the more lines are needed so I cant just set it and forget it :/
Publié : 21/01/2022 2:43 am
Yes you can.  When in expert mode there is a red setting available called "Minimal filament extrusion length:"  As long as there is at least 1 loops defined the setting is not greyed out.  This makes the skirt use that much mm of filament.  Note skirt and NOT brim.  There is a difference.
Publié : 21/01/2022 7:46 am
woogerboy21
(@woogerboy21)
Oh... ill have to try this as well...
Publié : 21/01/2022 2:07 pm
nvcheeko
(@nvcheeko)
Just do Purge Line at start of GCode
Publié : 25/01/2022 9:10 am
XemereSmoe
(@xemeresmoe)
Yes, it's the good way!
Publié : 27/01/2022 9:25 am
