PS271 - Cut Connectors don't represent confirmed position when sliced
I've been using the Cut command and adding connectors to my model. It appears that when slicing, the placed connector shifts position from what I originally specified.
The hole portion of the connector is properly placed in the other piece for this shift, but the original placement was made to make it easier to place the cut piece and this shift makes it more difficult to get the correct orientation.
Has this been seen before?
Connector design:
Connector after slicing:
Opublikowany : 16/01/2024 1:34 pm
