PS V2.8.0 Can't seem to add my custom profile for Flashforge Creator Pro IDEX machine
Frank
(@frank-8)
I have been using a custom profile in PS for my Flashforge Creator Pro IDEX machine for several years now.  I now have a new PC and I'm trying to get the new setup to recognize my custom Flashforge Creator Pro IDEX machine profile, without much success.
On my old PC, all I had to do was use the existing BIBO dual-extruder .INI file as a template and change all occurrences of 'BIBO'-ish to 'Creator Pro2' and then place that file in the c:\users\frank\appdata\roaming\PrusaSlicer\vendor folder.  That no longer seems to be the case with 2.8.0.  I have looked through all the documentation on the GitHub site, and I'm more confused now than before I read through it- doesn't seem to make a whole lot of sense.
Anyone else had any luck getting Prusa to recognize a custom profile?
TIA,
Frank
Opublikowany : 08/08/2024 8:40 pm
Frank
(@frank-8)
I've attached a screenshot showing what PS 2.8.0 looks like on my old PC, with 'Flashforge.ini' in the C:\users\Frank\AppData\PrusaSlicer\vendor folder
And my FlashForge.INI file (changed to Flashforge_INI.TXT to get by filters)
Opublikowany : 08/08/2024 10:07 pm
Pontus Renmarker
(@pontus-renmarker)
RE: PS V2.8.0 Can't seem to add my custom profile for Flashforge Creator Pro IDEX machine
Hej,
I had the same issue. Simply add the FlashForge.idx file to the vendor path:
C:\Users\<yourusername>\AppData\Roaming\PrusaSlicer\vendor
Restart the program and run the Configuration Wizard again.
Opublikowany : 25/09/2024 2:47 pm
