PS slicing cylinders with flat top and bottom
Jim B
(@jim-b)
Hi All,
Having an issue where cut out cylinders on all four sides of the vertical walls of a grid are getting a flat top and bottom.  I've gone thru every setting I thought might make a difference, but nothing has made a difference.  This appears to be an issue with newer slicers, as two years ago this object sliced fine, and I was able to insert magnets fine.  Now with flat top and bottom, magnets don't fit.  Strangely Cura does the same thing with the flat spots.  Not sure which settings are worth mentioning, but I have 2 top and bottom layers.
Any thoughts as to how I can fix this?
Thanks.
Respondido : 19/11/2020 10:42 pm
