PS 2.8.0 SSL Connectivity with Octoprint
Martin Stoufer
(@martin-stoufer)
Versions:
Prusa Slicer 2.8.0 (Mac-x64)
Octoprint: 1.10.2
Attempts to send sliced files to a local LAN Octoprint server are failing with:
Could not connect to OctoPrint: SSL peer certificate or SSH remote key was not OK:
SSL: certificate verification failed (result: 5)
[Error 60]
Note: OctoPrint version at least 1.1.0 is required.
Its a self-signed cert that has been trusted in the Keychain and does not expire until next year. I'm attempting to reach it via https://octoprint.local I've also verified the API key is correct. It worked just fine in prior PS versions.
I can reach the web front end just fine from seperate Chrome browser and the embedded "Physical Printer" tab. Chrome tells me the self-signed cert is all valid and its happy to use it.
Has anyone else hit up against this?
I can provide more logs if needed.
Respondido : 03/07/2024 12:46 am
jamie
(@jamie-2)
RE: PS 2.8.0 SSL Connectivity with Octoprint
I am experiencing the same problem with the following stack:
MacBook Pro running Sonoma 14.5 and PrusaSlicer 2.8.0+MacOs-arm64
I am running Octoprint on a Pi Zero 2w connected to my Prusa mk3s+ via USB cable:
Octopi with Octoprint 1.10.2 on Raspbian GNU/Linux 11 (kernel version 6.1.21-v7+)
OpenSSL 1.1.1w 11 Sep 2023
HA-Proxy version 2.2.9-2+rpi1+deb11u6 2024/01/05
Respondido : 07/07/2024 5:27 am
Martin Stoufer
(@martin-stoufer)
Issue filed with Prusa: https://github.com/prusa3d/PrusaSlicer/issues/13005
There are some other users reporting the same. Please add comments there for better visiblity.
Respondido : 22/07/2024 10:01 pm
jamie
(@jamie-2)
There has been no response from Prusa since the GitHub issue was opened.
Respondido : 27/07/2024 8:19 pm
JonB
 JonB
(@jonb-3)
Miembro
I'm having the same issue if anybody has a fix
Respondido : 21/09/2024 8:36 pm
