PS 2.8.0 SSL Connectivity with Octoprint
Versions:
Prusa Slicer 2.8.0 (Mac-x64)
Octoprint: 1.10.2
Attempts to send sliced files to a local LAN Octoprint server are failing with:
Could not connect to OctoPrint: SSL peer certificate or SSH remote key was not OK: SSL: certificate verification failed (result: 5) [Error 60] Note: OctoPrint version at least 1.1.0 is required.
Its a self-signed cert that has been trusted in the Keychain and does not expire until next year. I'm attempting to reach it via https://octoprint.local I've also verified the API key is correct. It worked just fine in prior PS versions.
I can reach the web front end just fine from seperate Chrome browser and the embedded "Physical Printer" tab. Chrome tells me the self-signed cert is all valid and its happy to use it.
Has anyone else hit up against this?
I can provide more logs if needed.
Posted : 03/07/2024 12:46 am
