PS 2.4.0 Bug With Negative Volume
MadMax
(@madmax-2)
Negative volume works correctly on single color models or multicolor models where the negative volume only intersects one color. If the negative volume intersects more than one color on a painted model, PS crashes to desktop. Tested and repeated on several painted models. 1) added negative volume that only intersects one color works ok. 2) added negative volume that intersects 2 or more colors, immediate crash to desktop on slicing. 3) tested on two different computers with various models.
Maybe someone else could test this for the same behavior?
Opublikowany : 26/12/2021 3:12 pm
fmceng1@gmail.com
(@fmceng1gmail-com)
RE: PS 2.4.0 Bug With Negative Volume
I also have discovered this BUG after I installed the new version 2.4.0 Christmas Day.  Completely shuts down the slicer the instant I use a negative volume that cuts more than one color painted with the slicer.  Lets hope they solve this soon for it is a great tool when using multi material prints.
Opublikowany : 27/12/2021 12:23 pm
MadMax polubić
If you have found a bug you need to report it. Unfortunately here is not the correct place. All issues need to be reported https://github.com/prusa3d/PrusaSlicer/issues
Opublikowany : 27/12/2021 1:16 pm
MadMax
(@madmax-2)
Thanks, I wasn't sure where to report it.
Opublikowany : 27/12/2021 1:33 pm
