PrusaSlicer with SL1: "SLA supports outside the print area were detected"
Pete Brown
(@pete-brown)
Top-down slicer viewAny idea why this happens? Is the default SL1 configuration not accurate? I end up having to move the items around until it finally passes, which is not an equal distance from all sides. There's no indicator (as far as I can tell) as to which supports are outside the print area.
Using PrusaSlicer-2.0.0 on Windows 64 bit
Pete
Best Answer by JoanTabb:
Hi Pete,
That issue seems to have been resolved in Prusa Slicer 2.1.0 Alpha1
Opublikowany : 13/08/2019 12:02 am
RE: PrusaSlicer with SL1: "SLA supports outside the print area were detected"
Could it be that the supports in the middle were overlapping?
Obviously not a good description, but I have had similar issues!
Joan
Opublikowany : 13/08/2019 12:20 am
Pete Brown
(@pete-brown)
Posted by: joan.t
Joan
That may be the case. I would think that overlapping supports would be fine. Maybe there's some reason not to allow that?
Pete
Opublikowany : 13/08/2019 12:30 am
Hi Pete,
I would think so, too, but we dont know what logic is in slicer, and it may be defective logic.
which slicer are you using?
Joan
Opublikowany : 13/08/2019 12:32 am
Pete Brown
(@pete-brown)
Posted by: joan.t
Hi Pete,
Joan
Ha, thanks 🙂 I'll have to keep my eye out for overlapping supports, then.
Prusa Slicer 2.0.0 64 bit on Windows 10
Pete
Opublikowany : 13/08/2019 12:45 am
Hi Pete,
Opublikowany : 13/08/2019 12:53 am
Pete Brown polubić
Pete Brown
(@pete-brown)
Excellent! Thanks Joan. 🙂
Opublikowany : 13/08/2019 12:54 am
Link here,
the download is below the change log
https://github.com/prusa3d/PrusaSlicer/releases
it's an Alpha release, so report any bugs please and beware you might get unexpected errors...    always a risk with Alpha software.
Joan
Opublikowany : 13/08/2019 12:56 am
Pete Brown polubić
