PrusaSlicer with SL1: "SLA supports outside the print area were detected"
Any idea why this happens? Is the default SL1 configuration not accurate? I end up having to move the items around until it finally passes, which is not an equal distance from all sides. There's no indicator (as far as I can tell) as to which supports are outside the print area.
Using PrusaSlicer-2.0.0 on Windows 64 bit
Pete
Best Answer by JoanTabb:
Hi Pete,
That issue seems to have been resolved in Prusa Slicer 2.1.0 Alpha1
RE: PrusaSlicer with SL1: "SLA supports outside the print area were detected"
Could it be that the supports in the middle were overlapping?
Obviously not a good description, but I have had similar issues!
Joan
Joan
That may be the case. I would think that overlapping supports would be fine. Maybe there's some reason not to allow that?
Pete
Hi Pete,
I would think so, too, but we dont know what logic is in slicer, and it may be defective logic.
which slicer are you using?
Joan
Hi Pete,
which slicer are you using?Joan
Ha, thanks 🙂 I'll have to keep my eye out for overlapping supports, then.
Prusa Slicer 2.0.0 64 bit on Windows 10
Pete
Hi Pete,
Excellent! Thanks Joan. 🙂
Link here,
the download is below the change log
https://github.com/prusa3d/PrusaSlicer/releases
it's an Alpha release, so report any bugs please and beware you might get unexpected errors... always a risk with Alpha software.
Joan
