Prusaslicer Vasemade preview skips/combines layers
I am having a problem when checking vase-mode preview/g-code
I set 30 bottom layers.
In preview, layer 0.2mm and 0.4mm are combined into preview for 0.2mm.
Afterwards, 0.4mm preview shows 0.6mm, and future layers are offset by 0.2mm
Then, at preview 2.8mm, it skips 2.6mm. Instead, it shows layer 3.0mm. And also, the left/right preview only displays the perimeter, and not the solid layer.
Layers about this continue this, and are now offset by 0.4mm and do not show left/right preview of the solid layer.
I'm doing this because I am trying to concatenate vase-mode gcode with a normal gcode using this: https://github.com/supermerill/SuperSlicer/issues/2984#issuecomment-1311057202
Napsal : 30/04/2023 1:21 am
