PrusaSlicer Test Report: Filament List & Usability Issues
Laurent Khiati
(@laurent-khiati)
🧪 PrusaSlicer Test Report: Filament List & Usability Issues
Issue Summary The selectable filament list under the filament tab is shorter than the list used for filament comparisons, which results in unnecessary steps and configuration overhead. Additionally, the lack of a scrollbar and case-insensitive search functionality makes navigation inefficient.
Steps to Reproduce
Open PrusaSlicer and go to the Filament tab.
Attempt to select a filament from the predefined list.
Compare this list with the filament comparison list (e.g., from the Prusa Materials Guide).
Notice missing entries.
Try searching by name using different letter cases ("PETG" vs "petg")—results aren't found unless casing matches exactly.
Scroll down the filament selection pane—note there's no scrollbar, requiring tedious mouse-wheel scrolling.
Expected Behavior
The selectable filament list should include all filaments available for comparison.
A scrollbar should appear for long lists.
Search functionality should be case-insensitive and responsive to partial matches.
Current Workaround To access missing filaments, users must:
Create a custom filament profile manually
Copy and paste settings from comparison data
Save and reimport it for slicing
This adds unnecessary complexity for users who rely on efficient workflows.
🧪 Rapport de test PrusaSlicer : Problèmes de liste de filaments et d'utilisabilitĂ©
Résumé du problème La liste de filaments sélectionnables est inférieure à celle utilisée pour les comparaisons, ce qui génère des manipulations inutiles. De plus, l’absence de poignée de défilement et de recherche insensible à la casse complique l’utilisation.
Étapes pour reproduire
Ouvrez PrusaSlicer et allez dans l’onglet Filaments.
Essayez de sélectionner un filament depuis la liste prédéfinie.
Comparez cette liste avec celle du guide des matériaux Prusa.
Certains filaments sont manquants.
Tentez une recherche avec des noms en casse différente ("PETG" vs "petg")—aucun résultat si la casse ne correspond pas.
Essayez de faire défiler la liste—aucune poignée n’apparaît, le défilement est fastidieux.
Comportement attendu
La liste de filaments devrait inclure tous les matériaux disponibles.
Une barre de défilement devrait apparaître pour les longues listes.
La recherche devrait ĂŞtre insensible Ă  la casse et plus fluide.
Solution de contournement actuelle Pour accéder aux filaments manquants :
Créer un profil de filament personnalisé
Transférer les réglages depuis les données de comparaison
Sauvegarder et réimporter pour l’utilisation
Cela ajoute une complexité inutile pour les utilisateurs avancés comme débutants.
Veröffentlicht : 20/07/2025 6:13 pm
RE: PrusaSlicer Test Report: Filament List & Usability Issues
I'm afraid you are posting in the wrong place. This is a user to user forum and the Dev's don't use here.
Anything Prusa related must be posted over at their official github.
For prusa slicer related issues that is located here https://github.com/prusa3d/PrusaSlicer/issues
For settings specific issues that is https://github.com/prusa3d/PrusaSlicer-settings/issues
Please follow the submission guidelines and please do a search of both OPEN and CLOSED issues before opening new ones. There are over 4.9K open ones already and over 8.5k closed ones so a lot of ground has already been covered.
Veröffentlicht : 20/07/2025 7:42 pm
