PrusaSlicer Split Connectors Arrangement
huczekdesign
(@huczekdesign-2)
Hello!
Just tested out the new feature in prusaslicer to add connectors to my part and I have to say I'm impressed. Very cool that I can do that while slicing and negate the time needed to model them.
However I have a question regarding this that was hoping you all could answer.
Is there a way to add these connectors in a straight line in the slicer? Certain command I need to hold while adding, camera view to use, etc? I tried to eyeball them using the grid pattern in my UI but that is far from perfect and ideally I'd love to be able to just say I'd like 3 connectors, spaced equally on this line? Is that simply not possible without modeling them first in CAD?
It's not a big deal if that's simply a limitation, but just wanted to check if there is something obvious I'm missing here.
Thanks!
Opublikowany : 04/09/2023 4:52 pm
2 ludzie polubili
