PrusaSlicer see only Home directory LInux
[Risolto] PrusaSlicer see only Home directory LInux
Tsantsa
(@tsantsa)
Utenti
Hi guys.
PrusaSlicer refuses to load an STL file from another disk (Loading of a model file failed.), while it can load the same file from the home directory without any issues. I'm using PrusaSlicer 2.7.2 on Linux POP OS 20.04, and I've been scratching my head over this for month, and I don't know where the problem lies. In fact, PrusaSlicer doesn't see any of the other disks, while other applications don't have this problem.
Discs are mounted, all others app do not have the problem, everything is updated, PrusaSlicer was reinstalled several times from different sources.
Every suggestion is welcomed as my Home is getting quite full and I do not want to reshape partitions only for one stupid app.
Postato : 07/05/2024 10:09 pm
This sounds like a file permissions or user/group problem.  Check the properties on your files and mountpoints.
Postato : 08/05/2024 12:16 am
Tsantsa
(@tsantsa)
Utenti
RE: PrusaSlicer see only Home directory LInux
all mounts/files have permision and slicer have same permisions like rest of apps. If you are right the problem should manifest also for another apps.
Postato : 08/05/2024 8:15 am
Tsantsa
(@tsantsa)
Utenti
Problem was in mounting point, PrusaSlicer can not see disk mounted outside of /media/user/... most of apps can
Postato : 09/05/2024 8:08 pm
OK, symlink.
Postato : 10/05/2024 1:07 am
