PrusaSlicer (Resin) print removed holes?
thedevilsjester
(@thedevilsjester)
The new version of PrusaSlicer added the ability to hollow a model out and punch a hole in it for draining; which is a great feature but unless I am missing something, is only half complete.
In Chitubox when I dig a hole in a hollowed print, it has an option to keep that "slice" and puts it on the build plate so I can print it. After draining and cleaning, you can use it plug the hole with (almost) no visible artifact.  This lets me cut holes in places that I would otherwise avoid, because a little touch up and its like it never happened.
Is there a setting in PrusaSlicer that lets it print the removed portion?
Opublikowany : 28/04/2020 2:47 pm
Area51
(@area51)
RE: PrusaSlicer (Resin) print removed holes?
Have never seen that setting in PS, but I think it is a good idea.
Best place to suggest that new feature is to make a Feature Request issue here.
Opublikowany : 28/04/2020 10:39 pm
