Prusaslicer Profile Dependency trickery need help
MC
 MC
(@mc-3)
Our club has 3 MK3s with different nozzle sizes and Filaments.
I want to create Print profiles that can be copied to a lot of computers.
In Prusaslicer I want to choose a Physical printer.
Than there should ONLY be the Filaments and Print settings that I have created and NOT the Prusa ones.
Like if you create a new Printer from scratch and create Filament profiles and Print setting Profiles for that. (I don‘t do that because I still want to keep the bed shape model and texture witch also gets lost if you detach from system present)
So I need Help with either a way how you can transfer bed shape and model to other computers or with Dependency trickery. What would be best?
I tried around for hours but no Luck.
Best Answer by bobstro:
I have notes on creating custom profiles and setting dependencies here that might be helpful. In short, yes. I have 3 printers, each with associated filament and print profiles. Using dependencies, I only see the relevant presets for each printer and nozzle combo.
Respondido : 23/07/2021 11:07 pm
Ringarn67
(@ringarn67)
@mc-6
Here are the files for bed and texture
C:\Program Files\Prusa3D\PrusaSlicer\resources\profiles\PrusaResearch\mk3_bed.stl (bed model)
C:\Program Files\Prusa3D\PrusaSlicer\resources\profiles\PrusaResearch\mk3.svg (the lines on the bed)
If you detach printer from system preset you can add the above files in "Printer Settings" - "General" - "Bed shape".
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.6.1+win64, Fusion 360, Windows 10
Respondido : 24/07/2021 9:16 am
1 les gusta
MC
 MC
(@mc-3)
reply
Posted by: @ringarn67
@mc-6
@ringarn67
thanks for the paths.
how do I do it, so that you simply have to coppy over profiles to a new PC and the bed model is still shown? Those profiles will be used with Windows, Linux and Macs. So I imagine if I hard Link to those Files, it will only work for Windows PCs.
Do you think I can Include those files in a Profiles Folder and than softlink to them?
Respondido : 24/07/2021 10:10 am
Yes, you can do this with dependencies
Respondido : 24/07/2021 3:49 pm
1 les gusta
Ringarn67
(@ringarn67)
Sorry...
@ringarn67
I only have Windows Pc's so I am afraid I don't have a clue 😌
Respondido : 24/07/2021 11:25 pm
Config bundles work well across all platforms
Just create config bundle files and users on any platform can easily import them.
Respondido : 24/07/2021 11:36 pm
MC
 MC
(@mc-3)
your notes solved my problem
your notes solved my problem.
I changed the Printer name from MK3s to Prusa_gruen in the printer file and checked the checkbox to single extruder multi material. don't know what that does but it hides every Prusa print and filament profile that I did not create.
in my profiles I wrote as compatible conditions:
printer_model=~/Prusa_gruen.*/
Respondido : 24/07/2021 11:48 pm
1 les gusta
Dependencies are clumsy, but they do work!
Glad it worked for you. The dependencies are a bit clumsy, but they do work. Hopefully, Prusa will make them easier to work with in future releases of PrusaSlicer.
Respondido : 25/07/2021 4:28 am
