Prusaslicer print time is almost twice as long as Cura is that normal?
Im printing on the Neptune 3 pro. My main slicer is Cura but wanted to try out Prusaslicer 2.6.0 alpha 3. When I import the same STL into both. I have the settings as close to the same as I can see other then speed. The print times after slicing after almost double of that of Cura. Im thinking it's speed related as the speed setting, just not sure what I need to change in Prusa. Thanks for any help
Also meant to put this in the Cura sub.
This topic was modified 3 years temu by J P
Opublikowany : 13/02/2023 11:47 pm
