PrusaSlicer postprocessing script
MichaelK
(@michaelk)
The latest PrusaSlicer has the following Post-processing script
D:\Programs\python36.exe D:\Programs\PrusaSlicer\post-processing\PrusaSlicer_post-processing.py;
Where did this come from.
What does it do ?
And how do I install the files needed
Opublikowany : 07/01/2020 12:43 am
Nikolai
(@nikolai)
RE: PrusaSlicer postprocessing script
Where have you got the PS from? Which version are you running?
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 07/01/2020 12:57 am
MichaelK
(@michaelk)
I'm running PrusaSlicer 2.1.1 (201912101512)
If PS means the script, it came with the install of PrusaSlicer, because I didn't install it.
Opublikowany : 07/01/2020 1:01 am
Nikolai
(@nikolai)
PS = PrusaSlicer. The script is defined in the print settings. I don't see that in the default system presets. Please check if you've imported something special and cross check your system presets.
Often linked posts:
Real Multi Material
Opublikowany : 07/01/2020 1:09 am
MichaelK
(@michaelk)
I just uninstalled PrusaSlicer, and reinstalled it
The script isn't there now.
I don't know where it came from.
Opublikowany : 07/01/2020 1:16 am
