PrusaSlicer object location vs actual print
Alter3go
(@alter3go)
Im printing 2 copies of an objected, which basically fills the complete bed.
When the actual file started to print, I noticed that it is a bit off to the right, when compared to the preview in PS, as shown in the attached.
Would this have to do with the nozzle offset? Im using the E3D Revo, with the E3D mount, which if I remember correctly, should be on the exact same as the original nozzle.
How can I move the nozzle to the left in the Gcode? I could actually do with that extra few mm on the left to add mouse ears to the corners of the print .. haha
Thanks
Opublikowany : 25/01/2023 12:53 pm
RE: PrusaSlicer object location vs actual print
Thats because of where your printer thinks zero is for X.  Its common for stock printers too.  You basically have to make sure theres nothing blocking the left travel on X and redo the machine calibration from the startup again to 'reset' where it thinks zero is.
Opublikowany : 25/01/2023 1:30 pm
1 ludzie polubili
