PrusaSlicer - leaving fill/breather for resin fill
Hi there,
I would love to resin fill a model I have. Infilled with Gyroid. I'm thinking of methods to have a fill/breather hole into the infill?
Is this something that can be easilly done in Prusaslicer, other that me having to manually remove some of the model's skin.
Thanks,Steve
RE: PrusaSlicer - leaving fill/breather for resin fill
Hi there,
Thanks,Steve
Yes!
Rightclick model, "Add Modifier", Pick someone you like, (my guess is "Cylinder"), adjust to right size and place it where you want
In the right tab, click cog wheel at "Generic Cylinder", click "Infill" and then "Layers and Perimeters"
Adjust "Bottom solid layers" and "Top Solid Layers" to "0" (zero)
Done! 👍
Prusa i3 MK3S+ FW 3.11.0 (kit dec -20), PrusaSlicer 2.5.0+win64, Fusion 360, Windows 10
Perfect, thank you for the clear answer. I'm still learning PrusaSlicer, but like it a lot. Coming off of Simplify3D.
Cheers.
