prusaslicer isnt printing anything lower than 0.5mm
andre.17780
(@andre-17780)
any idea to fix that?
Publié : 02/04/2020 6:04 pm
RE: prusaslicer isnt printing anything lower than 0.5mm
Doesn't it?
Publié : 02/04/2020 9:42 pm
andre.17780
(@andre-17780)
@joantabb
check this photo and the next one, there is a figure 0.4 and after slicing it, it dissapear, and it always happen with lower than 0.5mm to me https://www.facebook.com/photo.php?fbid=1156281171430523&set=a.1156281121430528&type=3&theater
Publié : 02/04/2020 10:09 pm
@andre-17780
Andres, I am sorry I have no idea what you are asking, I see two pictures, one appears to be 3deditor view of a thin item with an Expamet type surface, and the other appears to be a picture of a sliced first layer with three perimeters, No indication of the width of the squiggly lines or the thickness of the squiggly lines or the thickness of the entire model,
Can you  please Zip the STL and attach it to the post,
or can you Zip the 3MF file of the project and add that to the post please
possibilities I recognise include Inappropriate first and successive  layer heights and inappropriate nozzle size / extrusion width settings
Publié : 02/04/2020 10:38 pm
andre.17780
(@andre-17780)
@joantabb
https://mega.nz/file/qgghlByS
the texture is just a mesh made with pipes
Publié : 02/04/2020 11:06 pm
@andre-17780
It's encrypted...
Joan
Publié : 03/04/2020 12:16 am
andre.17780
(@andre-17780)
it doesnt let me upload the file, can you share me your email pls
Ce message a été modifié il y a 6 years 3 fois par andre.17780
Publié : 03/04/2020 2:09 am
@andre-17780
Sorry Andre, I was asleep...
I have downloaded your STL. and will hopefully have a completed print in about 15 minutes...
Attachment removed
Publié : 03/04/2020 5:58 pm
andre.17780
(@andre-17780)
@joantabb
THANK YOU
Publié : 03/04/2020 8:40 pm
@andre-17780
This is what I got...
white is not the best colour for detail, but it is what I have today...
Publié : 04/04/2020 12:12 am
andre.17780
(@andre-17780)
@joantabb
i get the same, it mean it didnt print the pipes because those are smaller than 0.5mm, is the slicer fault.
Publié : 04/04/2020 1:10 am
Andre I dont have your model but if you are running a normal .4mm nozzle then the default extrusion widths will be set in the slicer to .45.  This means that parts smaller than .45 wont be sliced as the details are too small.
Settings such as detect thin walls can help with this but as its a software algorithm its effective can vary alot depending on the model.  You can also set your extrusion widths to be 0.4, then features down to that size will be printable.
Joan has shown that parts smaller than 0.5 are printed so what exactly is the issue ?
Publié : 04/04/2020 11:11 am
andre.17780
(@andre-17780)
@neophyl
hi, if you see the image of joan, i get the same result, that circle, is over 0.5, but the pipes over the circle are under 0.5, that is why those pipes arent printer and you see only a plain circle. i tried lowering the nozzle to 0.2 but still got the problem, im going to try to modify the extrusion width directly and i will tell you how it goes, thank you.
Publié : 04/04/2020 2:58 pm
andre.17780
(@andre-17780)
@neophyl
sir you are awesome, it fix it, now the software slice it
Publié : 04/04/2020 3:20 pm
andre.17780
(@andre-17780)
@neophyl
nevermind, it now show it, but doesnt print the pipes, something wrong with the gcode.
Publié : 04/04/2020 4:42 pm
andre.17780
(@andre-17780)
@neophyl
