Prusaslicer is putting support materiel inside model instead of infill
gigagod777
(@gigagod777)
Membre
lighter test.1-4forum.3mf
How do I fix this so the void inside the model's shell has infill and not the generated support material? Also how do I increase the thickness of the outer shell as at the minute it I only 1 layer thick even though I have changed the settings
Quite new to model making and the mesh was made in blender.
thank you in advance
V
Publié : 28/03/2025 9:13 pm
Snuffleupagus
(@snuffleupagus)
Membre
RE: Prusaslicer is putting support materiel inside model instead of infill
@gigagod777
The model your using is reporting some 700 errors.
Consider repairing the errors before Slicing.
Using PrusasSlicer on some, but not all, Operating systems, you may find that you have a feature to repair your models, by right clicking and selecting "Fix by Netfab", or whatever they are calling it these dayz. If that's not working for you then you'll need to take it back into a CADD software and fix it properly.
As for the one layer thick, repair the model and then we'll take another look, the model requires muchas correcciones.
Regards
Publié : 30/03/2025 6:45 am
