Prusaslicer is adding extra layers to parts of my prints
AlphaTech_
(@alphatech_)
Utenti
I'm trying to print this timetable but prusaslicer is just randomly adding layers to some parts of the print.
This is the stl:
and this is the generated g-code view:
Any ideas on how to fix this?
Postato : 09/02/2024 7:51 pm
RE: Prusaslicer is adding extra layers to parts of my prints
To be specific that's not the stl, that's a picture of the stl.  🙂
We would need at a minimum the stl you are having trouble with but ideally instead your prusa slicer project file.  Slice so you have the issue, then use File>Save Project As.  That will save the stl and a copy of your in use profiles into a PS 3mf file.  That 3mf is a snapshot of your slice, with it we can debug the problem much much easier.
Don't forget that you have to ZIP the file to attach them here, or the forum will just silently not attach.
Its likely to be a damaged or incorrect stl but you never know which is why the project is best.  Oh and also what PS version are you running and what OS is it running on ?
Postato : 09/02/2024 9:55 pm
1 persone hanno apprezzato
AlphaTech_
(@alphatech_)
Utenti
Here is the .3mf file:
timetable
I copied this from the system information tab in PrusaSlicer:
Version: 2.7.1+linux-x64-GTK3
Build: PrusaSlicer-2.7.1+linux-x64-GTK3-202312121425
Operating System: Unix
System Architecture: 64 bit
Resident memory: 838MB
Shared memory: 134MB
Private memory: 704MB
Peak memory usage: 846MB
RAM size reserved for the Undo / Redo stack: 1,074MB
RAM size occupied by the Undo / Redo stack: 4MB
Postato : 10/02/2024 5:37 am
good morning,
there are errors in the STL
if you are using windows, you could right click on the model and choose to fix it
I believe you may be using Linux, maybe someone else can help you find a repair tool
Postato : 10/02/2024 10:18 am
