RE: Prusaslicer is adding extra layers to parts of my prints
To be specific that's not the stl, that's a picture of the stl. 🙂
We would need at a minimum the stl you are having trouble with but ideally instead your prusa slicer project file. Slice so you have the issue, then use File>Save Project As. That will save the stl and a copy of your in use profiles into a PS 3mf file. That 3mf is a snapshot of your slice, with it we can debug the problem much much easier.
Don't forget that you have to ZIP the file to attach them here, or the forum will just silently not attach.
Its likely to be a damaged or incorrect stl but you never know which is why the project is best. Oh and also what PS version are you running and what OS is it running on ?
Here is the .3mf file:
timetable
I copied this from the system information tab in PrusaSlicer:
Version: 2.7.1+linux-x64-GTK3 Build: PrusaSlicer-2.7.1+linux-x64-GTK3-202312121425 Operating System: Unix System Architecture: 64 bit Resident memory: 838MB Shared memory: 134MB Private memory: 704MB Peak memory usage: 846MB RAM size reserved for the Undo / Redo stack: 1,074MB RAM size occupied by the Undo / Redo stack: 4MB
good morning,
if you are using windows, you could right click on the model and choose to fix it
I believe you may be using Linux, maybe someone else can help you find a repair tool
