Prusaslicer - how to select the tool before any temperature settings are output in gcode?
Hi, I'm totally new to Prusaslicer, having only used an old version of Cura up to now.
I'm trying to configure for an E3D toolchanger / Duet 3 6HC machine.
I have all the appropriate code in start.g to do general referencing & Z probe etc., but when I slice and export a job, the slicer is adding a temperature setting line (G10) before start.g is inserted and the machine is referenced or any tool is loaded?
It's only trivial, but is seems an odd behaviour?
Publié : 27/11/2021 8:50 pm
